What is the THICKEST, TOUGHEST oil I can put in my viper trans??
Old 03-20-2012, 01:08 PM
KILLER-LS1's Avatar
Default What is the THICKEST, TOUGHEST oil I can put in my viper trans??
Im doing some standing mile racing (200mph speeds) and i want something that will help with overheating. I know that a fluid pump would be ideal, but thats not an option right now. Im currently running GM Synchromesh. I was thinking about adding some lucas trans stop-slip (super thick & sticky additive).
any ideas on what fluid to use? the trans has all carbon synchros btw.
Old 03-20-2012, 07:26 PM
NVR_SPDS's Avatar
I run Royal Purple Synchromax in my Level V T56 from RPM Trans. Been running it for years, but ive never run it THAT hard lol.
Old 03-21-2012, 07:02 AM
HoLLo's Avatar
Thicker does not necessarily mean better... Just run a quality synthetic like Amsoil, RP, etc. I used Pennzoil Syncromesh and have no problems over many years. Great smooth stuff, but I hear the Pennzoil = GM Syncromesh
Old 03-21-2012, 08:32 AM
Jeremy@RPMTransmissions's Avatar
I agree with NVR_SPDS, Royal Purple Synchromax is what I would try.
Old 03-21-2012, 12:12 PM
gnx7's Avatar
unless you are hot lapping the car at Mojave.... your trans won't have heat issues.
Old 03-21-2012, 12:23 PM
When you are running the mile and making the kindof horsepower he is you start to overpower the gearset. That makes a lot of excess heat. He just wants to get one more mile event out of it befor it gives up the ghost.
Old 03-23-2012, 06:36 AM
oldmano2z's Avatar
gm syncromesh, does not break down. check with 24hr le-mans winners pratt and miller and see what they use.
Old 03-23-2012, 02:36 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Well, I can tell you what they don't use, and that's a T-56 or TR-6060, so their choice of transmission oil wouldn't exactly matter in this case.
Old 03-24-2012, 08:16 AM
oldmano2z's Avatar
they help gm with their corvette program. what trans do they use then??? the man was asking for fluid not trans and i have extremely good luck with syncromesh. they are changing it to an ac/delco part # by the way
Old 03-24-2012, 10:00 AM
MeentSS02's Avatar
They were using an Xtrac sequential, but I'm not sure if it's still the same transmission since they are now using paddle shifters.
And while he was asking about fluid, he was asking about fluid for a specific transmission, not just a random transmission, and certainly not a sequential gearbox.
From what I've found, the Dodge recommended Viper factory fill for '03-'06 Vipers is Castrol Syntorq (75w85)...that's far thicker than the Dex III ATF GM recommended for T-56s over those same years. I would guess Pennzoil Synchromesh is somewhere in between the two.
Old 03-24-2012, 05:53 PM
oldmano2z's Avatar
meetsss02, sorry for my confusion but what i ment to say was when pratt/miller ran their t56 they used gm synocromesh (the honey color) i have a t56 viperized how does that syntorq feel? i got some cryo and shot peen also, i want it to last. also have mgw. killer ls1 sounds like we both learned something here . thanks meents.
Old 03-24-2012, 07:21 PM
MeentSS02's Avatar
Couldn't tell you how the Syntorq feels...'08 is when Dodge switched to the TR-6060 to handle the extra HP ('08 was the first year for the 600HP 8.4L engine), and they also went back to a thinner fluid. From what I've found, Dodge went with the Syntorq to quiet down the neutral gear rattle noise that a lot of Viper owners dislike, but I'm guessing the thicker oil and the TR-6060 don't get along very well. My transmission definitely rattles in neutral, but it's just how the transmission is.
Old 03-25-2012, 09:08 AM
stevieturbo's Avatar
Exactly. It is just 1 mile, not 100 miles.
Quick Reply: What is the THICKEST, TOUGHEST oil I can put in my viper trans??
