help instal ticks master
Old 04-27-2012, 07:40 PM
mr.haha's Avatar
Default help instal ticks master
ok here is my problem its all in went to hook up pedal rod and (the looks to be) return spring bracket is in the way theres like a little ledge the other rod kinda rode on now with the hex rod it will not let the rod hook to the pedal just wonderin if any one else has had this problem and what the solution was remove bracket??? its a 2000 TA stock clutch stock slave any help appreciated
Old 04-27-2012, 09:04 PM
jmd
jmd's Avatar
Your user name has punctuation?
Old 04-27-2012, 09:09 PM
mr.haha's Avatar
yeah??????
Old 04-28-2012, 06:57 AM
mr.haha's Avatar
any one??????
Old 04-28-2012, 01:43 PM
TransamGCS's Avatar
pictures or small video would help i installed one on my ta dont remember having a issue like that
Old 04-28-2012, 02:57 PM
mr.haha's Avatar
I figured it out. the stud coming from pedal had burr on it and wouldn't let the rod slip over it. Once I sanded it a bit the rod slipped over. Put clip on, bled it , adjusted it. But no test drive its raining now. Thanks for the help. And I used my punctuation this time. Hope that helped the guy who got on me bout that thanks again
Quick Reply: help instal ticks master
