pedal position sensor b problem...after clutch install
Old 04-29-2012, 08:52 PM
lo&sloSierra's Avatar
Default pedal position sensor b problem...after clutch install
Just installed tick master and Nvm combo, in a 06 gto and the pedal seems to be adjusted right but the cruise doesn't work and I get a pedal position code...any ideas? I don't want to have to over adjust the pedal and risk damaging the pressure plate
MC combo*
Old 04-29-2012, 09:48 PM
jbridwelltransam's Avatar
I'm gonna have to say it is probably the sensor that touches the clutch pedal is not out far enough. Follow the pedal up and you should see a sensor with a flat part that looks like it should touch the pedal. Should be able to screw it out enough to fix your issue.
Quick Reply: pedal position sensor b problem...after clutch install
