Creeping in gear...
Old 05-25-2012, 02:01 PM
mateols1ss's Avatar
Default Creeping in gear...
Ok guys. I took my old clutch master out and did the drill mod and flushed the black dirty fluid it that was in it. I could not get the pedal feel like it was before i took it all apart. I bled for a few hours and nothing. I just picked up a new master from GM and transfered over the drilled hose but I have the same result. My car creeps in gear when the clutch pedal in down. I think the slave is probably bad. I dont want to buy a new clutch and slave if I dont have to. Do I just need to keep bleeding? It did get a little better tha last few times I bled it. By the way my car is a 00 so it had the older master in there.
