Pedal drop
Old 05-29-2012, 05:36 PM
LT1Air's Avatar
Default Pedal drop
When I get into it and start to catch gears my clutch pedal goes to the floor When I depress the pedal again it get pressure back and works fine. Any ideas?
LT1Air's Avatar
It is an ls1 btw
Old 05-29-2012, 06:30 PM
Boosterado's Avatar
Try searching the kabillion F body sticking clutch threads
Old 05-29-2012, 07:13 PM
calhoon's Avatar
Do a search for drill- mod or for orificed feed. Still the peddle dropping to the floor begs for more research.
Old 05-31-2012, 07:45 PM
LT1Air's Avatar
Sorry new to ls1s found the thread for the sticking pedal Just bought the car found out its already had the drill mod done and already had the slave cylinder replaced
Old 05-31-2012, 08:17 PM
Boosterado's Avatar
Keep looking. I had all the hydraulics replaced 3 time on my old car before I found out it was the pressure plate bending when it got hot. New clutch fixed the problem
Old 06-01-2012, 03:15 PM
SPEC-01's Avatar
If the Master hasn't been replaced this it may need to be. Of course a good flush and refill of the hydraulic fluid may do the trick too. I suggest trying this first. Use a Mighty-Van (vacuum aided bleeder) to help with the process and let us know if you see improvement. Thanks!
