clutch and headers install question
I am in the process of installing BBK LT's. In a couple months I was planning to do the clutch. My question is....Is there enough room to get the bellhousing off without having to remove the headers? Reason I ask is because I saw a extra charge from a shop for a clutch install if you have headers. As opposed to having remove all that crap again I may do it now.
Would it be easier with the headers out?
I kinda knew I would at least have to take off part of or all of the y-pipe but the person/vendor I talked to said you can't get the bellhousing off because of the headers. They charged a additional $170 if you have LT's for a clutch R & R. It's really open under there now with everything out so I think I might as well do it now....
