Viper/Mustang T56 behind an LS1?
Can it be done? I've seen some Viper T56 tranny listed lately. I assume I would have to change teh bell housing as when using an LT1's six speed:
https://ls1tech.com/forums/manual-transmission/154606-lt1-t56-behind-ls1.html
so does anyone know if its also bell housing, input (and possibly rear?) shaft and front plate?
Thanks,
ROCNDAV
Thanks,
ROCNDAV
LOL the 03-04 Cobras upgrade *their* mainshafts to the F-body mainshaft!
http://www.ddperformance.com/t56_partsupgrades.htm
D&D sells a Viper T56 that bolts in to the F-body.
http://www.ddperformance.com/GM%20T56.htm
$2300.
$2300.
Originally Posted by jmd
Also, the input on the Ford box is weaker due to lower # of splines.
At least Ford went with a clutch release setup that works.
but the clutch setup, agreed, other than replacing throw out bearings often, if its anything like the older stangs setup
Ryan
