Spec Twin Disc in 04 CTSV Clutch Shim Question
Old 02-10-2013, 05:10 PM
marc.madmax's Avatar
Default Spec Twin Disc in 04 CTSV Clutch Shim Question
I have the Spec Twin Disc in my CTSV and I don't think I have the correct Shim package from Spec. The adapter is about an 1.5 in and per measurement it looks like I need more like .5 inch. I had called spec and with out a pic they say its correct. I measured from where the trans hits the flywheel cover and compressed slightly the slave and its a little over 1.6". Then measured from flywheel cover to the fingers and its more like 2.1". Ideas?
I know I will try and call spec and find out the problem.
Spec CTS-V Super Twin 2-Disc SS-Trim (2004-07) (SC66SST-2)
Attached Thumbnails Spec Twin Disc in 04 CTSV Clutch Shim Question-clutch.jpg
Old 02-11-2013, 04:53 PM
Jeremy at Spec Clutch solved the riddle. seems I did not get the shim piece, probably lost in transit. but thankfully they will get me back rolling again.
Quick Reply: Spec Twin Disc in 04 CTSV Clutch Shim Question
