Fbody Clutch air bubbles video inside!!!!
Old 08-26-2013, 08:12 PM
MAXXLIMIT's Avatar
Exclamation Fbody Clutch air bubbles video inside!!!!
I'm using a Mitty Vac pump and going through the clutch resivour.
Does this look normal with the air bubbles coming out??? Is it usually this amount off bubbles when bleeding the system???
Old 08-27-2013, 10:59 AM
BALLSS's Avatar
assumeing you are not sucking the fluid out of the MC than yes those bubbles are normal on a bleed. if you are sucking fluid out also, try it with 5-7 psi
I did not have success with the MV and wound up bench bleeding MC then connecting to slave that also was bench bleed then pump slave from bottom until bubbles stop coming up is resovoir
Quick Reply: Fbody Clutch air bubbles video inside!!!!
