Help!!!!
Help!!!!
ok guys just bought the car, previous owner said master cylinder was going out so he gave me a tick unit, installed today still having the same problem....as i go through the gears when i get to 3rd and get to about 3500rpm sometimes lower sometimes higher all the car will do is seem like it is in neutral and just rev, i have installed the master cylinder and bled the system really good still does the same thing i am thinking its the throw out bearing holding pressure??? idk....previous owner said clutch was a spec stage 2+ that didnt have 4-5k miles on it
car is mostly stock
pacesetter headers and LM1 exhaust and a lid
car is mostly stock
Nothing should be under pressure when the clutch pedal is not being pressed. it sounds like the clutch slipping somehow. but if this is happening without you touching the clutch pedal it shouldn't be any of the hydraulics
I have a Spec stage 2 with also less than 4k miles on it. Having a whole ton of issues of my own that I now have to tear out the trans and also figure out whats up in there. Im replacing everything with an LS7 clutch kit, because based on what I've read and been told by more experience people, Spec set ups don't last.
