Does this Mantic 9000 look ready to install?
I'm doing some driveline upgrades as a preventative measure before doing any hard driving, racing,.....and eventually forcefully inducing air with a centrifugal style blower. This is a ls3 powered c5 corvette w/ a mm6, btw.
Bought this clutch used, and it just came in. It was said to only have been installed and ran on a dyno.....and no miles on the street. The sellers engine messed up and the drivetrain was pulled and parted out. I bought this with a RK built mm6 trans.
This is the first used clutch I've bought, and just want to make sure all looks good before I start the install.
I know some of you guys are probably pretty familiar with this, or this type of clutch.
Does everything look pretty normal? Especially the grooves in the flywheel surface?
