Clutch pedal issue
Clutch pedal issue
I drive a 2002 WS6 Trans Am m6 with a stage 2 clutch (fairly heavy clutch, so there is a lot of pressure on the pedal) and I've been having a problem with the clutch pedal... about a week ago, I pushed the clutch in to shift when I heard something break and the clutch stuck to the floor. I could pull it back up, and push it back down, but there was no pressure. I couldn't find the problem, so I had a friend who is good with these cars look at it. He replaced a small, circular E shaped part (not sure what it's called). After that it ran fine, no problems with the pedal at all, until today. The same thing happened again, I'm assuming the same part broke. This really freaking sucks cause it's currently my dd and I can't drive it if this keeps breaking every damn week. Just wondering if there's something I can do to fix this issue.
Sounds like the clip that keeps the master cylinders piston rod attached to the pedal. Happens quite a bit when I first got my car running , you can buy those clips at auto zone or any of those stores
