cammed ls1 6 speed guys quick question!
Alright I just bought a 2002 camaro z28 T56 and it has a tune/g5x4 cam/full exhaust.
of course at low RPM's the car wants to surge and buck a bit but at 50mph what gear do you guys run in? 5th or 4th gear? I'm running stock 3.42's if that helps. it feels like 5th may be too tall for 50-55mph but 4th also increases the RPM's, It makes it very difficult to maintain 50mph speed limits in 5th due to the surge I keep running up to 60mph unknowingly to avoid the occasional surge. I realize the cam is a "secret" cam and its a fairly good lift.
I never use 5th in the city. only time that happens is on this highway @ 65+mph. most of the time 3rd gear city and side streets. you sure your cam doesn't call for a different gear ratio? like 4:10s etc etc? this would help keep the engine in the right rpm range designed for that cam.
A lot of it is in the tune and it can usually be smoothed out pretty good depending how big the cam is. But what you have to realize is that once you get to a certain point on cam overlap, no amount of tuning is going to clean it up. You can't expect to putt around at 1500rpm in a high gear with a big ol 20* overlap cam and have it drive like stock. I'm not sure how big the g5x4 is though. I had a pretty big cam (30* overlap) in my 370 when it was a nitrous motor and it was still loping at 1700rpm lol. You desperately need some gears in that thing for sure though.
http://www.f-body.org/gears/
