Flushing clutch fluid
Old 04-22-2014, 08:15 PM
Z28 6spd's Avatar
Default Flushing clutch fluid
So I want to flush out the old clutch fluid on my 02 Z28 and just want some input on doing the job. The car has 16k miles and is essentially all stock - GM master cylinder, GM slave and original clutch. I've had zero problems with the clutch and am doing this strictly as a maintenance item to keep clean fluid in there. My plan is to suck out the reservoir and replace with fresh fluid and then use a mity vac on the bleeder screw to draw the fresh fluid through. I've searched on here and read a lot of clutch bleeding horror stories and just wanna make sure I'm not opening up a can of worms. I know the fluid degrades quickly so I would like to do this.
Old 04-22-2014, 09:17 PM
It's not mine! woo hoo!
demonspeed's Avatar
I don't believe it's as bad as some make it out to be. I simply get the car up on jack stands and bleed from the screw on the slave while I have a friend (or my wife) pump the clutch at watch the reservoir. Takes only minutes.
Old 04-23-2014, 09:14 AM
blackbyrd's Avatar
I'm a pretty big guy and getting under the car is tough for me so I'm gonna drill a hole on the inside if the car to access the bleed valve. Mine isn't a daily though
Quick Reply: Flushing clutch fluid
