GTO to F-body
gto has the steeper mn12 gear set but gets the upgraded triple con synchros on 1-2 and doubles on 3-6. It uses a different bellhousing for the gto starter and shifter offset lever. To run it in an fbody you need the offset lever and cup which is 35-40 bucks then either run a gto starter on the bellhousing or use an fbody bellhousing and starter
I bought a Hurst aftermarket F body shifter that works in the GTO T56 but you need the lever/cup for an F body in place of the GTO lever/cup in your trans.
Here's the part I believe you need:
http://www.thegearbox.org/catalog/it...17/7328789.htm
LS1TECH Sponsor
Thanks for the mention Steve!
GTO guys wanting to install an F-Body T56 need this Rear Offset Lever: http://www.tickperformance.com/treme...lever-for-gto/
F-Body guys wanting to install a GTO T56 need this Rear Offset Lever: http://www.tickperformance.com/treme...y-cobra-viper/
