Question about Sachs 1050 flywheel?
I'm putting a 5.3 in my '68 Nova with mechanical clutch linkage and trying to do it as cheap as possible. Can I run the Sachs 1050 flywheel, my current 10 spline 10.5 inch clutch disk and then a newer 11 inch metric pressure plate?
I saw Gary 68's thread about using an old 11 inch BBC pressure plate but it had to be dtilled out for the metric bolts. Isn't there a cheap jobber 11 inch pressure plate that will work?
Thanks
Thanks
