5th gear vibration in shifter
I just finished up a new McLeod RST clutch & flywheel install and I also installed a MGW shifter. Everything seems fine except 5th gear and sometimes 6th gear have a vibration in the shifter (not the chassis). Rear is factory 10 bolt with original 3.42 gears, factory suspension and torque arm. Car only has 48k miles on it. I don't know where to start looking. Before the new clutch & shifter it never had any vibrations.
The way you describe it doesn't sound like a problem with the clutch. Since you have done the clutch and shifter together you would need to reinstall the original shifter and see if you still feel the vibration.
I have had a few different shifter setups , none of which had the big rubber damper that the original shift lever had . They all transmit vibrations that the stock shifter would mute (especially the cheapy "short stick" type that simply replaces the lever and bolts to the original shifter base).
