LT1/T56 clutch change
I've got a 93 T/A stock LT1 w/ T56, is there a link or thread with pics on changing out the clutch anywhere. I've seen all the LS ones but if I'm not mistaken there is some difference. I've got to replace my clutch myself (can't afford to have it done plus I don't trust any shops here lol). Any help or advice is greatly appriciated!!!
Thanks Guys
Ron
Thanks Guys
Ron
Ron
There may be a link somewhere showing step by step. I would assume a Haynes service book would and certainly a FSM (factory service manual) specific to your year.
There really is not much difference in swapping out a LT1 "pull" type clutch vs a "push" type in most other stick cars
You need to remove at least the stick from the shifter or the shifter all together so some "interior" work is needed before you get under the car to pull tranny & clutch
couple of TQ values
76 ft lbs FW bolts
22 ft lbs Pressure plat bolts (important you don't over TQ these bolts)
couple of TQ values
76 ft lbs FW bolts
