Ls1 Clutch help please
Old 11-29-2014, 12:20 PM
robice_el's Avatar
Default Ls1 Clutch help please
I have a 98 ls1 firebird I am having a issue with. A little less that a year (10K miles) installed a new stock slave, RAM clutch kit, speed bleeder and Tick performance master. Recently I noticed that as I drive the car more (it warms up) the clutch won't disengage all the way. I decided to try and bleed it to see if that fixed it. Dark fluid came out and I now have clean fluid with no air in the system. However, now the clutch wont fully disengage at all and once it runs for a few min it becomes impossible to shift. I dont see any fluid leaking and there is no air. Suggestions?
Old 11-29-2014, 01:14 PM
chrysler kid's Avatar
Sounds like the clutch setup needed a shim behind the slave.
You can try an adjustable master cylinder but that's probably going to be a band aid fix
Old 11-29-2014, 01:35 PM
robice_el's Avatar
The tick master is adjustable and i have a thin shim now. Havent changed anything but this has started.
Old 12-01-2014, 01:45 PM
BALLSS's Avatar
maybe your clutch has worn (now thinner) and your MC needs to be adjusted some to compensate.
sounds like you have a disengagement problem. if on a flat surface motor running, car in gear, clutch pushed all the way down...does the car creep forward when you rev motor??
Old 12-01-2014, 05:27 PM
SNLPerformance's Avatar
What was the gap on your clutch setup? What size shim did you go with?
Old 12-02-2014, 10:59 AM
robice_el's Avatar
I dont remember. It was about a year ago. Do you know what the gap should be? I kinda guestimated it.
Quick Reply: Ls1 Clutch help please
