t56 front plate adapter bolt torque
I have two torque specs on the 11 bolts holding the adapter plate on my 04 GTO t56? Under the sticky here how to rebuild your t56 at the end it has 11 ft/lbs....doing some research I found 26 ft/lbs? Does anyone know?? The bolts are 10mm, so not small by any means to handle a pretty good torque load. Just don't want to possibly put any undo loading on the bearings.
So far i've put the ultra black on it and torqued it to 13lbft...11lbft seemed real low but the rebuild sticky has been up a while and no one has corrected it? If it is more, i think (or hope) from the flexibility of the silicone i can still torque down the plate with no consequences?
