clutch grinding when pressed
So yeah it grinds when I push the pedal down in 1st gear pull off I have a VERY shallow push till it starts grinding but I can get it in gear and pull away shifting into second it's still shallow but fading and still grinding at the end of the pedal push third gear it becomes noticeable that I can get more pedal towards the floor as such with fourth and 5th and 6th it's at the floor but it's grinding at the end of the pedal each time just the higher the gear the more pedal travel u get before it grinds. When I parked it and push the clutch in while in neutral if I forced the pedal into the grind to make the pedal hit the floor it would almost stall out the car. Please help
