LS7 flywheel install
I installed my LS7 flywheel, clutch and pressure plate over the weekend using new ARP bolts for the flywheel and pp. I torqued to the ARP recommended spec of 85ft lbs, but I can't remember for the life of me if I did the 3step torque procedure on the flywheel. Should I remove it all and reinstall just be sure its seated evenly?
