Monster Clutch Install Instructions & Slave????
Does anybody have the instructions for a Monster Level 3 Clutch kit? I would really appreciate it if someone would scan them and email them to me.
coryrgraner@yahoo.com
Also, with 34K miles, do I really need to change my slave cylinder when I do the install? Thanks for the help.
Moderator
Received 1,836 Likes
Check with SNL Performance. Guaranteed they'll have it.
36k isn't bad on a slave but also how long has it been in there? Seals can go bad just sitting. To me, the effort to pull the transmission twice vs the cost of a slave to only do it once, I would replace it. But that's me.
Are you keeping the stock master? Monster 3 is a great clutch but the stock master has a time with it. If you have problems getting it to disengage you might need to upgrade your master cylinder. TBH, it is debatable if the stock master is even adequate for the stock clutch in an F body.
http://monsterclutches.com/single-disc-install-tips
Give us a shout if you need more help. (817-750-2000)
Moderator
exactly right! I'm assuming you got the remote bleeder as well. If not, get it. It'll make for easy clutch bleeding - which don't normally go together in the same sentence.
