rev up car with clutch in and it moves...
last summer put in a spec stage 3 clutch slave and still had a sticky pedal. this year put a new master cylinder on and now it moves ahead with the clutch pushed in and revved up. ordered a tick master cylinder im assuming that will fix this whole problem? and likely not a good idea to drive the car like that?
i wouldn't drive the car if the clutch is not disengaging 100%.
the tick will fix your issue. be sure, once you have it installed,
to start the adjustment with the clutch pedal as close to the
firewall as possible, then adjust out from there.
does the spec stage 3 clutch require any shimming, or did you
measure to be sure ?
