Losing hydro fluid. Tick master. Is slave leaking?
I have a 99 TA. My clutch pedal was sticking to the floor if I held the pedal down and I would have to lift it with my foot so in April I bought a tick master cyl from the ws6store. I bleed all the air out of the line and had great pedal feel and everything worked fine then in July my clutch started to slip if I give it too much gas which doesn't surprise me since I've had the clutch for awhile it is a spec 2 clutch by the way but I did notice my master cylinder was low on fluid so I topped it off but notice after I drive it for a day I have to add more fluid to it. I don't see in fluid around the master so could the slave be leaking? Any ideas?
Moderator
Received 1,836 Likes
Yes your slave is probably leaking. Possibly the bleed valve is very slightly cracked.
