Tranny rebuild question
My car has been grinding its 3rd, (intermittently, around town usually not, always at high rpm) and 4th (99% of the time 4th does grind) gears for maybe 2k miles.
After talking to a transmission technician I work with, he scared me a little, saying that it might not just be synchros, but the actual gears themselves could need replacing. Could this be true? 4th is the input shaft, correct? I can't imagine if my 3rd gear had teeth sheared/grinded down that it would transfer power and work properly at all.
I've had a hard time finding the answer to this question, as I myself thought when gears start grinding, as long as the gear still engages and works, you only need synchros, and obviously forks/pads etc upon rebuild.
It would be difficult to tear down, being as its my dd. It seems like quality 3rd gears are hard to fine too.
I guess I'm looking for other peoples experiences, like how often people needed to order gears when doing rebuilds, or if its always almost just blocker rings, synchros etc. I gave Tick a ring today, they through out "Ehhh maybe a 75% chance your 3rd is good" lol
