Clutch pedal still sticking to the floor?????
I've read many posts about this problem, but before I spend more money on parts I want to make sure this will fix it. About 2 weeks ago I had no pedal pressure and had a new clutch & slave put in. After bleeding several times I still have no pedal pressure. The car will drive, but I have use my foot to raise it back off the floor. Someone told me to get a new master. The car is a 99'. Will a new master cure the problem or should I bleed it more?
