loctite flywheel bolts?
Old 06-30-2005, 08:43 PM
1Z4U2NV's Avatar
Default loctite flywheel bolts?
I just completed my first clutch install and I realized i forgot to put loctite on the flywheel bolts. Should i pull the transmission again to put the loctite on or will it be fine the way it is. btw the clutch is a ram powergrip hd and a ram billet flywheel. thanks for any help
Old 06-30-2005, 09:42 PM
Michael Ozorowsky's Avatar
In past I did NOT put loctite on and was fine. This time put locktite on.
Old 07-01-2005, 09:36 AM
LS1TECH Sponsor
Steve Burger's Avatar
I always use red loctite on the FW and PP bolts.
Old 07-01-2005, 11:31 AM
Derek98z's Avatar
Me too. I would worry too much about one working even slightly loose and then getting uneven wear on clutch parts.
But if you torques to the correct specs, you might be alright
Old 07-01-2005, 04:47 PM
Senior Member
Country Boy's Avatar
+1...
Old 07-01-2005, 06:09 PM
GETSOMZ28's Avatar
+2 to using loctite
