need hydraulics purchase help asap!!!!
i need to do a clutch swap asap and i already have my mcleod single disk set up from my other car. i dont however have the adj master cylinder and i will need the upgraded slave. i see on a few sponsers pages that they sell a gm upgrade kit for about 280. now is that a stock master in those kits?? speed ink has one for example part #gm4101. i called chevy and they want both arms for the slave alone $200 and the mcleod adj master is both legs and some other jewels at over $300. i saw ram has an adjustable master for 170 but ive heard its a stock one only modified?? i also found the undated slave on a few sponsers page for between 110 and 130 depending. so my question is what would u do? i need to make the decision by this weekend because my cars barely driveable and dont want to ruin anything else.
btw i dont want to modify my stock master i want to replace it so thats out of the question. thank guys!!!
Here's a link for the slave http://www.texas-speed.com/item_deta...?ProductID=118 If it were me and this is what I did, change the slave and then if you hyd.. issues then go with the new master. Mcleod I beleve is the only maker or there own master.
