mcleod install tomorrow
im installing my mcleod single disc, 01 slave, and ram adj master tomorrow am is there any tips u guys have to help it along. i printed up the install guide on install university and i plan to bench bleed the master. i already unbolted the brake master, took out the rear o2's, removed exhaust bracket, took out driveshaft and torque arm, and unhooked all wiring. seems to me shes ready to come out.........will i still need to shim the slave with an adj master?
well my master never showed up so i wont be bleeding it 2day. the overall install was tuff but the only back breaker was lining up the trany when putting it back in. other than that fairly straight forward. but then again i didnt do the dreaded master yet. which sux be cause im moving in 2 days
