Is an adjustable master a safe alternative to shims?
I have a spec 3 ceramic in my car.. Been in there for about a year.
No shims.
My slave went out, and I'm currently having the trans rebuilt (no 3/4) and putting in the new slave..
In all my reading, I found a lot of things about shims for the spec clutches.. and I'm wondering if my adjustable master is fine or should I look into possibly getting a shim for my setup?
No shims.
I dont think an adjustable master will affect the motion of the slave, which is what the shims do. The shims lengthen or shorten the slave to make it contact the pressure plate sooner or later. The adjustable master allows you to change the engagement point of the pedal. You will be beating around the bush so to speak.
Originally Posted by ls2 bait
when i pulled the stocker out of mine it didnt have any shims so i didnt put any back on the new one. wont know how it works for another day or 2 though.
