Ls1 A4 To M6 Ques.
Ls1 A4 To M6 Ques.
I am in the middle of the conversion, and I cant seem to find the wires I need to change the neutral safety switch and extend them to the clutch safety switch, the reverse lights wires and the reverse lock out solenoid (cant get it in reverse). Also, if anyone can tell me what the white plastic switch that looks similar to the brake switch that goes on the clutch pedal does? TIA for any help at all as I need to get this car rolling ASAP.
ok.. you can take the nipple out of the reverse lockout solenoid and that will stop the issue with reverse.. although now you can accidentally throw it into reverse when going for 5th.
I have mine out.
You can run a switch to a power source and switch on the lockout noid and then shut the switch off when you are done.
I got mine done last month.. LOVE IT.
I have mine out.
