Help new clutch slipping!!!! why
Just put in a new spec 3 clutch, put 300 miles on it then went to the track.
on hard lauches the clutches spins wont grab. normal driving it cool when i lay into it it wont grab. do i need more break in time. this is my 3rd spec i installed never had this happen. also got it dyno tuned didnt do so well. could the clutch been slipping then on the dyno they where sprayin it. all info would be helpful. thanks
the pressure plate came with lock washers right? mine did, there should be no reason it should back off then did you bleed your clutch properly? also did you change your slave cylinder, if so did you put the shim behind it?
