mcleod master adjusting?
can someone please explain how they adjusted their master. how far of pedal travel before engagment. little explanation of how to adjust. thanks. just want to confirm.
wrencher
I always adjust mine to the freeplay's feel. I get it to about 1/8 1/4 inch freeplay in the pedal b-4 the master is compressing fluid. That always gives me the best feel & release point.
You can move the release point slightly but risk over or under-adjusting it. It is a slim window of adjustment there.
If you want to lower the engagment point take freeplay out of the pushrod. If you want to raise the release point you need to put freeplay into the pushrod.
