New Clutch And Slave Pedal Engaging on floor
Just installed a new Centerforce Duel friction clutch and Gm slave and. i blead the clutch some and it it ingages on the floor but it does grab hard. Should i bleed it more to get the pedal back or what....
Originally Posted by BadBlueT/A
There is a shim behind the slave. Could it be that i need to bleed it more
I installed a newer slave cylinder, this did not correct the problem at all and neither did any amount of bleeding.
So I yanked the trans (for the third time) and made some extra shims out of sheet aluminum. Clutch was fine after that. I installed the Mcloed adjustable master with my next clutch.
