Spec Stage 3
Old 09-08-2005, 05:01 PM
TKGN1's Avatar
Default Spec Stage 3
I am wondering what all comes with the stage 3 clutches?
The 2 parts that I am concerned with is the slave cylinder end. Has this been modified from SPEC in any way? The other is a light green disk about 5 inches in diameter. What is this used for?
-Grant
aka: Blackhawk131
I am using my friends computer.
Old 09-12-2005, 09:33 AM
Vertigo's Avatar
That light green disk is probably your slave shim. Before you put you slave on you tranny throw that shim on first, this will reduce slack.
