help diagnose my clutch problem...
First off I used to have problems with the fluid turning black and clutch slipping bad.
In the past I just flushed the old and put in new and it ran just fine, plenty of driving afterwards.
Then recently went black again, slipping was real bad. I flushed and flushed it, still had a problem, then I was suggested that i replace the Master. Did that, when I pulled it out I even had rubber sediment coming out of it. The car runs better but still slips.
What do you think my problem is? Do you think maybe I still have air in the lines, I figure I have well bled it.
If its not, think its a bad slave? bad clutch?
car is an 00, at 7k miles, hydraulics clutch and flywheel were replaced. Car now has 52k, so its 45k on the hydraulics, clutch and flywheel.
just a bolt on car, but its run pretty hard, and I have a record of eating clutches.
so what do you suggest is my issue at this point?
still air in the lines?
bad slave?
bad clutch?
bad slave?
bad clutch?
