Bleeding clutch master
I was just looking on install univ and was a little confused Is the bleed valve on the master or ubove the line going into the trans please help I am going to bleed system tomarrow
ok...theres the line that goes into the tranny...and just above it is a bleeder valve...
takes a 12mm socket, and a buddy...
one of you needs to pump the clutch..and hold it in...while the other loosens the valve after the clutch has been pressed all the way in and held in...
then close the valve after it has sprayed air and fluid all over the person under the car(LOL)
then the person holding the clutch in can release it and punp some more....
rinse lather repeat....until all the air is gone....
Thanks I was confuesd because it looks as if there is a bleeder on the slave from the pics . Do you think i can use a vacume bleeder or is it to receced to get the hose on Thank the info was a big help
i recently bought a motive power bleeder. your take off the clutch fluid reserve and connect the bleeder to the line. you then pressurize it to 5 to 9 psi and you open the purge valve, u then press and depress slowly 4 times this worked perfecly for me. i had been having problems with the regular purging since last december i finally got it working right.
