McLeod Twin Disc Issues...
Old 10-20-2005, 02:29 PM
BQTransAm's Avatar
Default McLeod Twin Disc Issues...
I think I have broken or damaged one of the discs in my clutch setup. It is very noisey, lots of chattering. The car drive fine with normal driving, as long as I don't slip the clutch too slow. If I slip it too long normal or try to take off hard, it slips bad, and burns up. If I try and wrap a gear out and shift at wot to the next gear, the clutch slips bad, burns and the clutch pedal doesn't come all the way up. I am going to tear into it this weekend, but my question is, can you order a new clutch disc for this setup, or am I going to need a all new flywheel to pressure plate setup...
