Popping out of gear?
Shirley Temple Drinker
Well, I know that usually means syncros. But its only done it twice, both in fourth, when deaccelerating ( clutch in ) Will it get worse? Could it be that maybe i didnt have it all the way in gear?
Try doing a search and see what other's have going through and done to try to solve this issue. I had the same problem and just had it fixed. I have a C5 though! I repleced my shifter linkage and its gone now, but you don't have a linkage like I do because your tranny is attached to you motor . My issue was in first gear though.........man was it annoying.
Good luck
Your right, I should have searched, sorry.
