Flywheel bolts
Flywheel bolts
This may seem like an odd question but i recently just purchased a LS1 dropout. It originally had an auto trans on it. I took the flexplate and torque converter off so I could put on my flywheel that I just had resurfaced and a Spec stage 2 clutch. Does anyone know if the auto tranny flex plate bolts will work in conjunction with the manual flywheel? I know some manufacturers makes seperate bolts for auto and manual trannies. I just don't want to have my flywheel shoot off or something stupid because I had the wrong bolts in. Of course thread locker will be used if they happen to be okay.
Also will it be okay if I use off the shelf bolts for the pressure plate? When I bought the setup the trans was seperated from the engine. I am thinking of going out and buying grade 8 bolts. Thanks in adavance everyone!
-Alex
-Alex
