What is the newest 6 spd. I can use with an old style motor?
Say a 80's style small block. Do they all bolt up or did the bellhousing patern change at any time. Anything else to look out for? Will a standard old style flywheel work with the newer trans? - I am looking to swap a 6 Spd into a 70 Chevelle behind a 406 Small Block.
Any comments or suggestions are welcome.
Thanks.
LK
Thanks.
LK
If you have the old bell and release system, you would be better off going with a T56 made for older applications. The 1386-000-011 is an aftermarket model made for GM retro-fits.It accepts the old fork, clutch. T-O bearing and 4-bolt bell.
