How can i tell ...
How can i tell ...
Im in the process of installing a new clutch. My last clutch was a spec stage 3 that with the steel flywheel.
My question is. How can i tell if my slave is still good ? Reason im asking about the slave is because i installed a used spec stage 2 clutch in my car only to find that it was doing the same thing my stage 3 was.. Slipping like crazy. The stage 2 i got used but it was till had alot of life left on it just not sure why it started slipping. I bled the clutch with the mighty vac and it keeps on getting air bubbles no matter how i bleed it or how many times. What does that mean ?
I have a new throw out bearing ready to go in and im making sure i dont need a new Slave. How can i tell if the slave is still good ? Car is a 2002 camaro SS with 35k miles
Also, does anyone have a part number for the 02 Slave ?
