Master cylinder install on a C5
Will be installing an LS6 master in a C5 this week and wanted some tips or tricks/write up on the procedure. I can barely see the master under the brake booster.
Thanks,
Doug D
Thanks,
Doug D
Its easy just disconnect the rod from your clutch pedal. then either turn or remove the front left tire, then the wheel well panel( the big black inner fenderwell piece). then disconnect the QD fitting. I removed my resivoir to make removal easier. Now turn the Master until the locking tabs line up with the slots on the firewall and pull it forward. The big black boot will come out with it. Now the fun part is working it out of the fender well. This is how I did it took 1hour.
