T56 vs Viper 6 speed
Old 02-04-2006, 08:30 AM
TT402LS1's Avatar
Default T56 vs Viper 6 speed
Is the gears in a Viper trans. the same as a Camaro/Firebird T56? If not, what are the gears ratios 1st-6th?
Old 02-04-2006, 03:25 PM
2002_Z28_Six_Speed's Avatar
I don't think it is really the same transmission. I mean to say they similar and share some parts. It seems like it has a different gear box, though.
I found this at the following link, http://www.vipercompetitioncoupe.com...ications.html# :
Gear Ratios
1st ..... 2.66
2nd ..... 1.78
3rd ..... 1.30
4th ..... 1.00
5th ..... 0.74
6th ..... 0.50
Old 02-04-2006, 03:35 PM
TT402LS1's Avatar
Thanks for the link and info!
Old 02-04-2006, 11:42 PM
I think the T56 is also different in the Corvette. The GTO gears also differ from the Corvetter. Don't know the stats off hand. You got choices to make!
Old 02-05-2006, 08:18 AM
TT402LS1's Avatar
I bought a Viper trans. for my 71 Chevelle. The shifter is forward more, so I can use the stock consol. (as told by D&D) Thay also recommended using a Viper trans because all the mods they due to the Camaro/Firebird trans. is already done. They claim it should hold up well to my twin turbo LS1 making 750-850hp @ the flywheel.
Old 04-06-2006, 11:36 PM
glhs422's Avatar
Who makes a bellhousing to bolt a viper t56 to an ls1 block?
I'm assuming the bolt pattern is completely different on the viper trans, right?
Old 04-07-2006, 06:39 AM
calhoon's Avatar
The pree 03 Vipers had essentially the same gears/ internals as an Fcar. Major dif was in the iron 3/4 fork from the factory.The 03-later units do have dif gears although the ratios are the same. The VIPER bell to block pattern is different( obviously) and the bell to T56 adapter pattern is a little off but useable.The "swap" will also require an input shaft change as well as a clutch release system rework.
Quick Reply: T56 vs Viper 6 speed
