big problem
Old 02-16-2006, 01:28 PM
ls1marine's Avatar
Default big problem
i have a 98 T/A with a stage 4 clutch and a built tranny and both are pretty new and now i went out to my car and it would not let me go into any gear at all does anyone know why
Old 02-16-2006, 03:14 PM
Camaroholic's Avatar
Engine running or engine off?
If the engine is off and you can't get it in to any gear, you have serious problems.
If the engine is running, then the clutch isn't disengaging. That's a hydraulics / clutch throwout issue. How's the pedal feel?
Old 02-16-2006, 06:50 PM
ls1marine's Avatar
ok its going into gear when the car is off and the pedel was super easy to push down but now it is just staying down
Old 02-16-2006, 07:28 PM
mrhzk35404's Avatar
sounds like the hydrolics.
Old 02-16-2006, 07:49 PM
styles2769's Avatar
master cylinder would be my guess, I had the same problem...only mine went out when I was driving. My clutch exploded and took out the cylinders, pressure plate, and flywheel.
Old 02-16-2006, 08:11 PM
ls1marine's Avatar
damn that sucks man and yea its probly the master because the slave was just replaced last month so do u know how much a new master cylinder is
Old 02-16-2006, 08:18 PM
It'd be under $200 for a master cylinder. They're not too bad to install, just takes a little time and patience. But it is definitely one end or the other...
Several of our sponsors sell them. I'd probably stick with a GM one. You might hit up KJ@SDPC (Kris) to see how much he sells 'em for.
