Quick question on my purchasing choice!
Hey guys, I've decided to go ahead and replace my flywheel and clutch, and I've noticed a few combos that seem to be used most.
Spec 3 / Fidanza flywheel,
LS7 Clutch / LS2 flywheel,
From here my question is how would the LS6 clutch and flywheel work since I noticed a kit on SummitRacing.com that includes both for 457 bucks.
I was pissed at first because it crapped out so early but I figure it just gave me an excuse to upgrade like I wanted haha.
Also why not go with the Spec flywheel if you get the Spec clutch?
And I really would like to go with a LS7 clutch and LS2 flywheel, but I can't find where to view prices and such so any clue to where I could look?'
And if I wanted to go ahead and replace my clutch master and slave cylinders can I get the 01-02 instead of mine (99) and it be a direct fit?
Thanks in advance.
Thanks in advance.
as far as the LS7 clutch set up figure it will cost around $550 give or take a little. Do a search for the part numbers. They are on here somewhere. or someone might chime in with them. You can then get prices from GM direct parts. or I believe that fred beans has been giving good prices on them. Again search is your friend
PR Director
Thanks in advance.
Thanks in advance.
