wheels wont spin
wheels wont spin
allright, my brother and i changed out the clutch on his stock 2000 TA with a clutch from a Z06. everything went allright, but when i finished putting everything back together i started it up and then had some problems.
keep in mind that the wheels were touching nothing, the entire car was jacked up off the ground.
i let the clutch out, and there was a little spittin and sputtering from the engine, but it finally went into gear, the wheels spun fine, with no gas. I then tried to give it some gas, and the engine bogged down, refused to rap up at all. i then let out the clutch, and reved up the engince just fine.
Any ideas? any feedback would be greatly appreciated. thanks in advance
Mike
Mike
