Need advice on adjustable master cyl. ASAP!
Old 02-24-2006, 05:29 PM
maxf's Avatar
Default Need advice on adjustable master cyl. ASAP!
Silly me, I haven't done my research ahead of time.
I'm planning on having my Spec Stage 4 installed this weekend. Along with that is an LS6 flywheel that has been refaced a BUNCH.
I made the dumb mistake of buying my clutch and flywheel used. The flywheel was in sh*t shape and the clutch is more torn up that it was represented to be. seller said there was only 500 break-in miles on the items Furthermore, the seller didn't care to include the shim that comes with the Spec clutch.
Now I have to figure out what to do. I don't really know how much has been taken off of the flywheel. The shop I had it refaced at had to take off 25, which is a lot more than I wanted gone. The seller told me the clutch had already been resurfaced at some point
Should I attempt to make my own adjustable master cylinder? (Using this tutorial.) Or should I attempt to find a RAM adjustable master cylinder over the weekend, which probably isn't possible?
HELP
