View Poll Results: Which clutch for my future mods?
Ram Performance Replacement Clutch Set
0
0%
Ram HDX Clutch Set
1
100.00%
Voters: 1. You may not vote on this poll
Which clutch do you recommend?
Old 03-05-2006, 06:42 PM
porksoda's Avatar
Default Which clutch do you recommend?
I finally decided to replace my Spec Stg. 2 clutch with a Ram since it went out the other day. The car is a 94 Pontiac Trans Am. My decision comes down to either a Ram Performance Replacement Clutch Set or a Ram HDX Set. I can't make up my mind because I don't know which would be better for the setup in my car. I do know that the Replacement Set is rated for 375hp and the HDX is at 425hp. Currently my car has all major bolt-ons and some suspension work but I also have a cam I may be putting in also.
The cam specs are as follows:
XE 227/233 cam with a 560/569 lift on a 1.6rr (114lsa)
7.2 Hardened Pushrods
Pro Magnum SA 1.6rr
CM-612 valvesprings with matching retainers and locks
The problem is that I don't have any idea what my car will be making after these mods and so I don't have any idea on the clutch to use either. Also I don't have any other plans for my car because it is my daily driver.
Quick Reply: Which clutch do you recommend?
